Raphael (and anyone with similar issues),
I’ve made some changes to the decoding; it works for all situations I
can test w/ my mailclients; except for the HTML; the code is still
displayed. I’ll look into that asap.
If the latest updates don’t work, please send an example mail to
helptest(a)oveas.net using the failing encoding format so I can parse
them in my test environment.
Please use some special chars in the header and the mailbody and a
description in the body as well.
If you send an email there, please notify me here so I know I have to
check my testsys
Oscar
I have discovered even more issues with the mail handling of the
tracker:
- html emails do not appear well in the tracker, the html code
becomes visible
- attachment to the email (such as screen copies) are lost! This is a
feature request for attachment to become linked files in the tracker
R.
I have just noticed several issues with the automated
processing of emails when these emails use UTF-8 characters
such as é è ï etc.
The issues are in the file class.tracker_mailhandler.inc.php
1) The function html::purify removes characters which are
encoded in latin1
2) there is no conversion of emails header / body received in
latin1 into utf-8
I have patched the file class.tracker_mailhandler.inc.php, but
i am worried the patch may not work in all situations
Index: tracker/inc/class.tracker_mailhandler.inc.php
--- tracker/inc/class.tracker_mailhandler.inc.php
(revision 27439)
+++ tracker/inc/class.tracker_mailhandler.inc.php
(working copy)
@@ -225,6 +225,7 @@
#return ($body);
break;
+ $body = utf8_encode($body);
return html::purify($body);
@@ -241,6 +242,7 @@
'elseif ($matches[2]
== "b" || $matches[2] == "B") { return base64_decode
($matches[3]); } ' .
'else { return
$matches[3]; } '
), $header);
+ $header = utf8_encode($header);
Raphael Alla
Alphalog Calédonie
Mitija Australia
+61 4 15 678 576
+687 78 86 86
http://www.mitija.com
http://www.alphalog.nc
Raphael Alla
Alphalog Calédonie
Mitija Australia
+61 4 15 678 576
+687 78 86 86
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World™ will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
_______________________________________________ eGroupWare-developers mailing list eGroupWare-developers@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/egroupware-developers
Oscar van Eijk
Oveas Functionality Provider
Zwaardenburg 63 – 3437 RJ Nieuwegein
T: +31(0)30 - 889 7812 – F: +31(0)30 - 889 9117
http://oveas.com – mailto:info@oveas.com
