Does anyone know how I can repair the issue I am having with access via Webdav my filemanager? Before the upgrade to 1.6.003 I was able to get into any of my directories. Now, I can get into the first level of the folders and the rest of what should be folders are showing as files, instead of directories. If I try to click on it, it returns with “unknown file type”
I was afraid I lost all my data that I had in the filemanager, but when I login to EGW and go to the filemanager, the data is all still there. I just can’t access it through webdav anymore. Is there something I need to do as part of the upgrade to refresh my connection to the filemanager?
I tried disconnecting to the webdav client and reconnecting, but same issue.
Your help would be greatly appreciated.
