I think there is a typo in the password. Two solution:
a) most simple: remove the header.inc.php file and start again
b) edit the header.inc.php and change the password hashes (at least 2)
with a cleartext password. After that you should be able to log into
setup again AND you should use the header admin (setup lower login) to
set the passwords again as hashes.
jvdwiel schrieb:
After running teh first two pages of setup I’m not able to login in the
Setup/Config Admin Login page. I always get Invalid password when I try to
login to start setup my database.
Who has an idea
http://sel.as-us.falkag.net/sel?cmd=k&kid0944&bid$1720&dat1642
