Hallo Ralf,
seit Revision 51267 (müsste diese sein…) scheitert bei mir um trunk das anlegen/ändern von Kalendereinträgen.
Fehlermeldung im Popup im FF/Chrome:
"An error happened
Unsupported value for parameters!"
Apache errorlog:
[Mon Jan 19 12:58:24.347319 2015] [:error] [pid 4837] [client 129.206.90.2:42793] An error happened (egw_exception_assertion_failed): Unsupported value for parameters!, referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.348283 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #0 [internal function]: calendar_so->events(1422284400, 1422288000, Array, 0, ‘all’, false, 0, Array, NULL), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.349013 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #1 /var/www/egroupware/calendar/inc/class.calendar_so.inc.php(577): call_user_func_array(Array, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.349637 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #2 /var/www/egroupware/calendar/inc/class.calendar_bo.inc.php(535): calendar_so->search(1422284400, 1422288000, Array, 0, ‘all’, false, 0, Array, NULL), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.350323 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #3 /var/www/egroupware/calendar/inc/class.calendar_boupdate.inc.php(263): calendar_bo->search(Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.350989 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #4 /var/www/egroupware/calendar/inc/class.calendar_uiforms.inc.php(800): calendar_boupdate->update(Array, false, true, false, true, Array, false), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.351637 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #5 [internal function]: calendar_uiforms->process_edit(Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.352288 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #6 /var/www/egroupware/phpgwapi/inc/common_functions.inc.php(1047): call_user_func(Array, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.352922 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #7 /var/www/egroupware/etemplate/inc/class.etemplate_new.inc.php(315): ExecMethod(‘calendar.calend…’, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.353512 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #8 [internal function]: etemplate_new->ajax_process_content(‘calendar_hansa_…’, Array, false), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.354185 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #9 /var/www/egroupware/phpgwapi/inc/class.egw_json.inc.php(163): call_user_func_array(Array, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.354816 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #10 /var/www/egroupware/phpgwapi/inc/class.egw_json.inc.php(82): egw_json_request->handleRequest(‘calendar.etempl…’, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.354882 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #11 /var/www/egroupware/json.php(105): egw_json_request->parseRequest(‘calendar.etempl…’, ‘{“request”:{"pa…’), referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.354923 2015] [:error] [pid 4837] [client 129.206.90.2:42793] #12 {main}, referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
[Mon Jan 19 12:58:24.354955 2015] [:error] [pid 4837] [client 129.206.90.2:42793] # Instance=default, User=hansa, Request=POST https://www.poppix.de/egroupware/json.php?menuaction=calendar.etemplate_new.ajax_process_content.etemplate, User-agent=Mozilla/5.0 (Windows NT 6.1; rv:35.0) Gecko/20100101 Firefox/35.0, referer: https://www.poppix.de/egroupware/index.php?menuaction=calendar.calendar_uiforms.edit&cal_id=7979
Gruß
Hansa
