I can repair only this way:
UPDATE egroupware
.egw_config
SET config_value
= ‘sql’ WHERE
egw_config
.config_app
= ‘phpgwapi’ AND egw_config
.config_name
‘contact_repository’ LIMIT 1 ;|
So set it back to SQL. What is wrong? Is my LDAP config?
Regards,
KAMI
Hi!
I have problem with LDAP contacts.
Currently I am using EGW with LDAP auth and login.
Select which type of authentication you are using: LDAP
Select where you want to store/retrieve user accounts: LDAP
It is okay. I can login it with ldap users.
Account context:
ou=People,dc=ceudata,dc=local
So my account exist here:
uid=myuser,ou=People,dc=cdomain,dc=local
Groups:
LDAP groups context:
ou=Groups,dc=cdomain,dc=local
It seems works.
I imported few contacts and decided to SQL.
Then I migrated informations from SQL to LDAP
The the imported contacts are listed under:
cn=myuser,ou=personal,ou=contacts,ou=People,dc=cdomain,dc=local
They are appear in addressbook for listing but not possible to edit them.
But after all there is no way to do addressbook’s site config (page with
header but the page is empty) Also adding a new contact is not possible,
because this page is also empty. What went wrong?
Thank you in advance!
Best regards,
Kálmán „KAMI” Szalai | 神 | kami911 [at] gmail [dot] com
My favorite projects:
OxygenOffice Professional http://ooop.sf.net/ - office suite - for everybody | Magyarul http://hun.sf.net/ - In Hungarian
Blog http://bit.ly/10ucTR | Support http://bit.ly/eYZO6
Follow me http://bit.ly/gJuJZ, if you can http://bit.ly/kDocB
