i realized a problem in addressbook when inetorgperson and
mozillaabpersonalpha shema are used together.
in so_ldap->egw2schema the faxnumbers are handled as the following:
‘inetorgperson’ => array(
‘tel_fax’ => '‘facsimiletelephonenumber’,
‘mozillaabpersonalpha’ => array(
‘tel_fax’ => ‘fax’,
This lead to a problem by saving because at least in debians
inentorgperson schema the fax is this:
attributetype ( 2.5.4.23 NAME ( ‘facsimileTelephoneNumber’ ‘fax’ )
DESC 'RFC2256: Facsimile (Fax) Telephone Number’
SYNTAX 1.3.6.1.4.1.1466.115.121.1.22 )
‘facsimileTelephoneNumber’ is just an alias for ‘fax’ and openldap
complains “attribute ‘facsimileTelephoneNumber’ provided more than
once”.
Is this just a debian problem? in case the other distributions shema
is equal to the debian one, i propose just to use “fax” in so_ldap-
egw2schema
cu
Cornelius Weiss
egw@von-und-zu-weiss.de
wengo: nelius (http://www.openwengo.org)
