Sebastian Ebling wrote:
To use LDAP authentication (which is working already) I have set the
/etc/sysconfig/saslauthd with SASLAUTHD_AUTHMECH=ldap
no problem. but I can not login to cyrus account to administer the
mailboxes.
because cyrus account use pam authenticatio. So is there any way to modify
/etc/sysconfig/saslauthd to support both pam & LDAP ?
Use PAM.
Install PAM module libpam-ldap and configure it to your ldap.
Use settings like this in /etc/pam.d/imap
auth sufficient pam_ldap.so
auth required pam_unix.so try_first_pass
account sufficient pam_ldap.so
account required pam_unix.so
Dear Sebastian,
Thanks for the solution. now I can login as cyrus which uses thye
pam_unix authentication. BUT ldap authntication is not working.
I hv checked the error log and below is the errors
Mar 5 11:01:33 linux slapd[4031]: do_extended: unsupported operation
"1.3.6.1.4.1.1466.20037"
Mar 5 11:01:33 linux slapd[4031]: conn=261 op=0 RESULT tag=120 err=2
text=unsupported extended operation
Mar 5 11:01:33 linux saslauthd[5731]: pam_ldap: ldap_starttls_s:
Protocol error
Mar 5 11:01:33 linux saslauthd[5731]: DEBUG: auth_pam: pam_authenticate
failed: User not known to the underlying authentication module
So here u can see the problem with starttls. so how to solve it ? for
security reason I like to enable it obviously.
hope after solving it I’ll have a fully working system with both
pam_unix and pam_ldap.
thanks for your guidance so far.
with best regards.
HTH
opinions on IT & business topics through brief surveys-and earn cash
