ich bekomme auf
certbot renew
diesen Fehler:
root@lab:/home/rainer# certbot renew
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /etc/letsencrypt/renewal/lab.hs-kl.de.conf
Cert is due for renewal, auto-renewing…
Could not choose appropriate plugin: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(“Could not find a usable ‘nginx’ binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly.”)
Attempting to renew cert (lab.hs-kl.de) from /etc/letsencrypt/renewal/lab.hs-kl.de.conf produced an unexpected error: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(“Could not find a usable ‘nginx’ binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly.”). Skipping.
All renewal attempts failed. The following certs could not be renewed:
/etc/letsencrypt/live/lab.hs-kl.de/fullchain.pem (failure)
1 renew failure(s), 0 parse failure(s)
Nachdem wir ein komplett neues Netzwerk bekommen haben habe ich die IP und die Nameserver in /etc/networks/interfaces geändert. Ein Ping z.b. auf Amazon.com funktioniert.
Habt Ihr evtl. noch eine Idee was ich machen kann?
beste Grüße
Rainer
