This is from web console when I try to open infolog. Only filter: responsible open.
Scrrenshot: https://clip2net.com/s/43JgQ5c
Loaded data
content: Object { action_id: 0, duration_format: “,dh”, css: “<style type=“text/css”>@media screen { .infoDes { max-height: 6.75em; overflow: auto; }}”, … }
currentapp: "infolog"
etemplate_exec_id: "infolog_gflower_5feV__gdVFEGbLFWDYVKFZ8P20ia4kgO80SmaWSwP0k="
langRequire: Array(3) [ {…}, , {…} ]
modifications: Object { “infolog.index”: {…}, “~custom_fields~”: {…}, customfields: {…}, … }
readonlys: Object { cancel: true }
sel_options: Object { info_type: {…}, pm_id: (1) […], info_priority: (4) […], … }
validation_errors: Array
: Object { … }
egw_debug.js:347:23
Loading infolog.index into #infolog-index etemplate2.js:386:22
Object { attributes: {…}, init: classExtend/prototype[name]</<(), destroy: classExtend/prototype[name]</<(), transformAttributes: classExtend/prototype[name]</<(), setNextmatch: setNextmatch(), loadFields: loadFields(), set_visible: classExtend/prototype[name]</<(), _genColumnCaption: _genColumnCaption(), _getColumnName: _getColumnName(), _ifacefuncs: (10) […], … }
Attribute ‘app’ does not exist in nextmatch-customfields! egw_debug.js:353:23
Object { attributes: {…}, legacyOptions: (3) […], prefix: “#”, DEFAULT_ID: “custom_fields”, init: classExtend/prototype[name]</<(), destroy: classExtend/prototype[name]</<(), assign: assign(), getDOMNode: classExtend/prototype[name]</<(), loadFields: loadFields(), transformAttributes: classExtend/prototype[name]</<(), … }
Attribute ‘app’ does not exist in customfields-list! egw_debug.js:353:23
Object { attributes: {…}, legacyOptions: (1) […], init: classExtend/prototype[name]</<(), transformAttributes: transformAttributes(), set_value: classExtend/prototype[name]</<(), _ifacefuncs: (9) […], constructor: Class() }
Attribute ‘rows’ does not exist in select-account! egw_debug.js:353:23
Widget
Object { _super: undefined, nextmatch: null, align: “left”, _mgrs: {}, _inst: null, _children: , _type: “nextmatch-customfields”, id: “customfields”, _parent: {…}, supportedWidgetClasses: (1) […], … }
: ‘@no_customfields’ was not of specified _type ‘boolean’ for attribute ‘disabled’ and is now ‘false’ egw_debug.js:353:23
Widget
Object { _super: undefined, align: “left”, _mgrs: {}, _inst: null, _children: (2) […], _type: “vbox”, id: “”, _parent: {…}, supportedWidgetClasses: (1) […], options: {…}, … }
: ‘@no_info_owner_info_responsible’ was not of specified _type ‘boolean’ for attribute ‘disabled’ and is now ‘false’ egw_debug.js:353:23
Widget
Object { _super: undefined, align: “left”, _mgrs: {}, _inst: null, _children: , _type: “customfields-list”, id: “$row”, _parent: {…}, supportedWidgetClasses: (1) […], options: {…}, … }
Widget
Object { _super: undefined, align: “left”, _mgrs: {}, _inst: null, _children: (2) […], _type: “vbox”, id: “”, _parent: {…}, supportedWidgetClasses: (2) […], options: {…}, … }
Object { fixedWidth: false, relativeWidth: false }
Attribute ‘order’ does not exist in undefined! egw_debug.js:353:23
Widget
Object { _super: undefined, align: “left”, _mgrs: {}, _inst: null, _children: (1) […], _type: “customfields-list”, id: “$row”, _parent: {…}, supportedWidgetClasses: (1) […], options: {…}, … }
Widget
Widget
Object { _super: undefined, nextmatch: {…}, align: “left”, _mgrs: {}, _inst: null, _children: (1) […], _type: “nextmatch-customfields”, id: “customfields”, _parent: {…}, supportedWidgetClasses: (1) […], … }
Widget
Widget
Widget
Had to skip a hidden popup - it should be removed
Object { 0: div#infolog-index_responsible_popup.et2_box.et2_box_widget.action_popup.prompt, 1: div#infolog-index_delete_popup.et2_box.et2_box_widget.action_popup.prompt, 2: div#infolog-index_link_popup.et2_box.et2_box_widget.action_popup.prompt, 3: div#infolog-index_startdate_popup.et2_box.et2_box_widget.action_popup.prompt, 4: div#infolog-index_enddate_popup.et2_box.et2_box_widget.action_popup.prompt, length: 5, prevObject: {…}, context: tr, selector: “.action_popup” }
egw_debug.js:353:23
TypeError: ex_mimes.split is not a function 2 jsapi.js:777:22
egw_get_file_editor_prefered_mimes jsapi.js:777
set_value expose.js:396
classExtend/prototype[name]</< egw_inheritance.js:244
setDetachedAttributes et2_widget_link.js:1624
NextJS 2
_dataCallback et2_dataview_controller.js:701
dataRegisterUID egw_data.js:643
dataRegisterUID NextJS
_insertDataRow et2_dataview_controller.js:380
_gridCallback et2_dataview_controller.js:437
_updateContainers et2_dataview_view_grid.js:821
