Hi Cyril,
Thanks a lot
just another question have you seen my other message about the bug Bug
ie11 and ie10 and adress book and the limitation of
1083 character in the url.
Hadi and I seen it, but had not time to fix is yet.
It would make sense to report it as bug on my.stylite.de, so we can
track it.
Should I create you a permanent account on my.stylite.de, or just open
that ticket for you?
Depends on you intending to to continue reporting bugs, specially IE
problems, or not.
Hi Cyril,
You are right! The issue is only in IE. I fixed it already and you can
update to r52849 to get the fix.
Here is link to the fix in svn changeLog:
http://svn.stylite.de/viewvc/egroupware?view=rev&revision=52849
Thanks a lot again for reporting this issue.
-Hadi
