Hi Sneaky,
Hello Ralf,
thanks for Your message.
Well, it’s a bit strange. It opens the Programm to show a pdf file (ocular),
but the pdf file seems to be empty.
When I open the file with kate, it shows me after the header a different
content than the original file downloaded without the password/login option
of egroupware. And the new file is shorter.
Can be two reasons:
a) you generate a Content-Length header and use strlen to calculate it.
As EGroupware sets mbstring.func_overload, this will give you a to small
length, if file contains non-ascii chars. We have a function bytes() for
that purpose.
b) other problem can be output buffering together with
zlib.output_compression php.ini setting
I think there is a problem with the codepage / charset, I tried to set it
manually in the fpdf.php, but nothing changes.
Is there a way to override the charset settings of egroupware or do You
think it is another error?
Thanks in advance,
sneaky
View this message in context: http://egroupware.219119.n3.nabble.com/Login-check-without-template-tp3992042p3992060.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
