I have now confirmed this send failure from felamimail in 1.2.106 using IE7,
Konqueror and Firefox on both Suse 10.0 and Mandriva 2005LE. The windows
java and apache logs are as follows: (Please send me a individual email to
send the ethereal trace to as, for obvious reason, I don’t want to post the
raw imap communications to the list)
FelaMiMail First Send Failures (apache & javascript log)
192.168.6.89 - - [02/Mar/2007:08:40:04 -0600] “POST /egroupware/xajax.php
HTTP/1.1” 200 40950
"http://mail.3111skyline.com/egroupware/felamimail/index.php" "Mozilla/4.0
(compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322)"
192.168.6.89 - - [02/Mar/2007:08:40:06 -0600] “GET
/egroupware/felamimail/templates/default/images/attach.png HTTP/1.1” 304 -
“http://mail.3111skyline.com/egroupware/felamimail/index.php” "Mozilla/4.0
(compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322)“
192.168.6.89 - - [02/Mar/2007:08:40:16 -0600] “POST
/egroupware/index.php?menuaction=felamimail.uicompose.action&composeid=271561
HTTP/1.1” 200 6700
"http://mail.3111skyline.com/egroupware/index.php?menuaction=felamimail.uicompose.compose”
"Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322)"
192.168.6.89 - - [02/Mar/2007:08:40:45 -0600] “POST
HTTP/1.1” 200 55
"http://mail.3111skyline.com/egroupware/index.php?menuaction=felamimail.uicompose.action&composeid=271561"
“Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322)”
Java™ Plug-in: Version 1.4.2_05
Using JRE version 1.4.2_05 Java HotSpot™ Client VM
User home directory = C:\Documents and Settings\david
Proxy Configuration: No proxy
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
Trace level set to 5: basic, net, security, ext, liveconnect … completed.
Cache size is: 87846926 bytes, cleanup is necessary
java.lang.NullPointerException
at sun.plugin.cache.CacheFile.getFileType(Unknown Source)
at sun.plugin.cache.CacheFile.before(Unknown Source)
at sun.plugin.cache.CleanupThread$1.compare(Unknown Source)
at java.util.Arrays.mergeSort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at sun.plugin.cache.CleanupThread.getFilesInCache(Unknown Source)
at sun.plugin.cache.CleanupThread.cleanCache(Unknown Source)
at sun.plugin.cache.CleanupThread.run(Unknown Source)
(second message composed) FelaMiMail First Send Failures (apache &
javascript log & ethereal trace)
192.168.6.89 - - [02/Mar/2007:08:45:04 -0600] “POST /egroupware/xajax.php
HTTP/1.1” 200 40950
192.168.6.89 - - [02/Mar/2007:08:48:56 -0600] “GET
/egroupware/index.php?menuaction=felamimail.uicompose.compose HTTP/1.1” 200
6537 “-” “Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR
1.1.4322)”
g: garbage collect
o: trigger logging
q: hide console
t: dump thread list
Trace level set to 0: none … completed.
(No java errors recorded on second mail compose and send attempt)
Can anyone else confirm this behavior??
David C. Rankin, J.D., P.E.
RANKIN LAW FIRM, PLLC
510 Ochiltree Street
Nacogdoches, Texas 75961
(936) 715-9333
(936) 715-9339 fax
www.rankinlawfirm.com
RSET)
Lars, Ralph (on sabbatical):
I have an ethereal capture of the problem with FelaMiMail failing on
its
first send attempt as described below. I have confirmed the problem with
1.2.106 on both Mandriva and SuSE distros. If you would like me to send
it,
just give me an address to send it to and I’ll be happy to do it. This is
a
strange problem…
Subject: [eGroupWare-users] lost connection after RSET
Mates,
On egw 1.2.106, I am getting smtp errors sending or replying to mail from
FelaMiMail. It seems to be unique to FelaMiMail as other mail
applications
don’t seem to give me this problem. Below are the log entries from a
single
mail transaction. What happens is that when you press send on a message,
the
first attempt to send fails for some reason and egw displays the message:
“SMTP Error: The following recipients failed:
david(at)notthe3111skyline.com” That
produces the first 4 log entries shown below:
Feb 27 20:11:26 bonza postfix/smtpd[5112]: connect from
bonza.rbpllc.com[127.0.0.1]
Feb 27 20:11:36 bonza postfix/smtpd[5112]: 68D7F6C4A3:
client=bonza.rbpllc.com[127.0.0.1]
Feb 27 20:11:36 bonza postfix/smtpd[5112]: lost connection after RSET
from
Feb 27 20:11:36 bonza postfix/smtpd[5112]: disconnect from
What is weird is that if you hit send again after it times out, the
mail
goes through without a hitch. See successful send below:
Feb 27 20:11:43 bonza postfix/smtpd[5112]: connect from
Feb 27 20:11:43 bonza postfix/smtpd[5112]: B6B3E6C4A3:
Feb 27 20:11:43 bonza postfix/cleanup[5113]: B6B3E6C4A3:
message-id=c5432637ffcf25a0f4428b01d343dde4@www.rbpllc.com
Feb 27 20:11:43 bonza postfix/qmgr[2400]: B6B3E6C4A3:
from=<david(at)onarankinlawfirm.com>, size=2106, nrcpt=1 (queue active)
Feb 27 20:11:43 bonza postfix/smtpd[5112]: disconnect from
Feb 27 20:11:43 bonza imapd[5116]: imap service init from 127.0.0.1
Feb 27 20:11:43 bonza imapd[5116]: Authenticated user=david
host=bonza.rbpllc.com [127.0.0.1]
Feb 27 20:11:43 bonza imapd[5117]: imap service init from 127.0.0.1
Feb 27 20:11:43 bonza imapd[5117]: Authenticated user=david
Feb 27 20:11:43 bonza imapd[5116]: Logout user=david
[127.0.0.1]
Feb 27 20:11:44 bonza imapd[5117]: Logout user=david
[127.0.0.1]
Feb 27 20:11:46 bonza postfix/smtpd[5112]: connect from
12-208-70-175.client.mchsi.com[12.208.70.175]
Feb 27 20:11:47 bonza postfix/smtp[5115]: B6B3E6C4A3:
to=<mark(at)kindsthemannfirm.com>,
relay=inbound.impacthosting.com[70.106.65.254],
delay=4, status=sent (250 Ok: queued as D3E1515EAD)
Feb 27 20:11:47 bonza postfix/qmgr[2400]: B6B3E6C4A3: removed
From picking around on Google a little bit, this error can be can be
caused if the mailer fails to issue a QUIT command at the end of the
previous smtp transaction. Do you guys know of anything else I could
check?
I would really appreciate your thoughts on this problem. Obviously, I can
hit send twice, but that doesn’t seem right. What say the gurus?
(936) 715-9333
(936) 715-9339 fax
opinions on IT & business topics through brief surveys-and earn cash
