In our instance unfortunately it still does not work: the window crashes if you try to enter data and the save and cancel keys are deactivated.
Also, after trying this, the mail compose window always shows the cc, bcc and folder fields, while it is normally set to the To: field only
Until a couple of weeks ago, we used it a lot, for emails related to working groups with multiple users.
Did anyone report a similar problem?
