Version info from /setup/
eGroupWare Version 1.9.020 (installed from apt-get Suse Source).
Replaced the files and options appear just fine. Doesn’t seem to be
authenticating at all regardless of the options setup:
Server being localhost or an external, with any of authentication options
(username/emailaddress).
Reviewing the logs doesn’t show any connections reaching either the POP3 or
IMAP server.
Hmm, hard to believe. I reworked the code before replying to you and
tested with SSL and automatic STARTTLS on IMAP (143).
Maybe you misunderstood some of the options, just post what you filed in
in setup and what your username in EGroupware and on the mailserver are.
Finally, inside the EGW suite it shows an audit trail of the accounts I’ve
tried to login, but as mentioned above it doesn’t seem to actually doing any
authentication checks. FWIW its worth, LDAP / Active Directory hasn’t worked
You must have some other problem. LDAP as well as AD are used in many
installations. Thought both can be trick with certificates, when using
ldaps (ssl), as validating certificates is switched on in PHP/LDAP by
default, but there’s no certificate store by default. This causes all
ldaps connections to fail!
Most easy, but of cause not a good idea security wise, is to disable
certificate validation by adding the following to OpenLDAP’s
/etc/openldap/ldap.conf:
TLS_REQCERT never
