Hi Gunda,
Hi Everybody
Our Hosting Provider TMD Hosting tells us that they have tried to
upgrade our Egroupware site V. 14.1 to latest, numerous times and
cannot get past the following error:
PHP Fatal error: Call to undefined function check_load_extension() in
/home/path/domain/egrp/phpgwapi/inc/class.egw_db.inc.php on line 507
This may be related to depreciated modules ie knowledgebase, wiki…
we are using under 14.1
Could anyone please give us some idea what the problem is and how we
can get past it?
They have not updated correctly.
In 16.1 phpgwapi/inc/class.egw_db.inc.php is only 33 line long, so
there’s no line 507. Seems to me phpgwapi is still on 14.1!
For updates NEVER overwrite the existing code with the new archive, it
will leave deleted files in place.
For updating to 16.1 you need the egroupware-epl-compat archive.
Thought you can remove it, after running the update and recreating the
header.inc.php, if you don’t use any of the old apps (thought you say
you do).
Many thanks in advance.
Kind regards
Gunda
Telefon +49 631 31657-0
