Hi Hans-Jürgen,
fixed it in trunk, EPL 9.1 and 1.6:
http://www.egroupware.org/viewvc/egroupware/trunk/calendar/inc/class.calendar_so.inc.php?r1=27926&r2=27925&pathrev=27926
Hans-Juergen Tappe schrieb:
Hi!
in 1.6.002, I get the following error when using a custom field
"Select Users" with a line number (multiple) of 2:
mb_strlen() expects parameter 1 to be string, array given in
/var/www/egroupware/calendar/inc/class.calendar_so.inc.php on line 601
It works, if I add array-awareness to the if expression in
calendar/inc/class.calendar_so.inc.php, lines 599 ff. to:
if ($name[0] == ‘#’)
/* Be aware of arrays and string inputs. */
if ((!is_array($value) && (strlen($value) == 0)) ||
((is_array($value)) && (count($value) == 0)))
$this->db->delete($this->extra_table,array(
‘cal_id’ => $cal_id,
‘cal_extra_name’ => substr($name,1),
),LINE,FILE,‘calendar’);
else
if (is_array($value))
$db_string = join(’,’, $value);
else
$db_string = $value;
$this->db->insert($this->extra_table,array(
‘cal_extra_value’ => $db_string,
),array(
Can you please fix this in head and 1.6?
Thanks a lot,
Hans-Jürgen
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
