Warning Message received…
Checking php.ini: mbstring.func_overload = 7:
ini_get(‘mbstring.func_overload’)='0’
The mbstring.func_overload = 7 is needed to fully support unicode (utf-8)
or other multibyte-charsets.
*** Please make the following change in your php.ini
(/usr/local/users/pow/r/a/pow.raleighc/php4/php.ini):
*** AND reload your webserver, so the above changes take effect !!!
I fixed this error without my php.ini file but it still shows up.
Did you remove the ‘;’ from the start of the line?
Are you sure that php-mbstring is installed?
Did you restart your webserver after changing the php.ini file?
What webserver are you using?
Jim McLaren
Get stuff done quickly with pre-integrated technology to make your job easier.
