I’m working on merge functionality, getting NELF command working in sub-tables.
It seems that there are different values for what to use for a linefeed in OO.o.
In one place, text:line-break/ and when doing NELF,
</text:span></text:p>text:ptext:span.
It looks like text:line-break/ will work for both, but I’m wondering
(@Stephan) about the problem
that resulted in this change:
http://svn.stylite.de/viewvc/egroupware?view=rev&sortby=file&revision=28862
so I don’t re-introduce it.
It seems that the span method assumes that there is a wrapping span,
which I have discovered is not always the case.
Thanks for any help,
Nathan
Free Software Download: Index, Search & Analyze Logs and other IT data in
Real-Time with Splunk. Collect, index and harness all the fast moving IT data
generated by your applications, servers and devices whether physical, virtual
or in the cloud. Deliver compliance at lower cost and gain new business
insights. http://p.sf.net/sfu/splunk-dev2dev
