Hello,
I get a daily report of an internet information platform (BSCW). There are links which lead you to files, which has changed or are new. If I click on such link I get the file, if I use Outlook Express. If I use felamimail, I get “Page not found”. I had talked with the hotline of BSCW and they mean, that the base URL ist missing in felamimail. BSCW sends the following header:
T=E4glicher Bericht
img { border: none }
So the prefix for every URL is “xxx.yyy.de/bscw/bscw.cgi/465562”. This works with Outlook Express, but felamimail don’t know about this and therefore it set a locale prefix.
This is a mail from felamimail:
