Hi All, I noticed that EGW reports this error /egroupware/api/js/offline/themes/offline-language-it.css:1 Failed to load resource: the server responded with a status of 404 (Not Found) I can’t figure out if something is missing in the installation or if I need to modify something. Any suggestions? Gabriele
No, you’re missing nothing.
The offline.js version, we have bundled, does not include Italian translation.
The current version does, so we need to update it (@hadi.nategh, if possible via npm or composer).
Thanks Ralpf, so if I understand correctly, an update will be made available? Gabriele
