Hi to all.
I have installed the funcambol plugin into my blackberry (Funambol BlackBerry Plug-in v.3.0.8 Community Edition)
my blkackberry is a 8700 (v4.1.0.258)
my egroupware is 1.4.002
i’m using php sessions
i have the xmlrpc active
if i go to http://myservername/egroupware/rpc.php
i get this
You should access this URL only with a SyncML enabled device.
i can successfully login from my blackberry to http://myservername/egroupware and see the egroupware in the blackberry web browser
but when i configure the funambol client with my username, password, the server url as http://myservername/egroupware/rpc.php
and check the synchronize addressbook only, with remote addressbook: ./sifcontacts (i dont know if this is right)
i get this
Synchronization failed, could not open tunnel - failed
I have no data iin the /tmp/sync folder or any sync log file
also i see not any data regarding this in the apache logs
could anyone give me any clue?
thanks
