Hello,
I am running a fresh install of EGroupware 1.8 on Ubuntu 10.04. When I
"uninstall" the news application I get an email from cron every hour
that complains about the egw_news table not existing. I have multiple
instances of EGW, and on some I want the news enabled and on others I do
not. Does anybody have any suggestions for this other than to re-enable
news on this instance?
The error I get is:
Database error: Invalid SQL: SELECT SQL_CALC_FOUND_ROWS 1,cat_name,cat_description,cat_data,cat_parent,cat_owner,cat_appname,count(news_content) AS num_news,MAX(news_date) AS news_date,egw_categories.cat_id AS cat_id FROM egw_news RIGHT JOIN egw_categories ON egw_news.cat_id=egw_categories.cat_id WHERE cat_appname=‘news_admin’ GROUP BY egw_categories.cat_id, cat_name,cat_description,cat_data,cat_parent,cat_owner,cat_appname ORDER BY cat_name :
Table ‘my_instance.egw_news’ doesn’t exist
#0 /usr/share/egroupware/phpgwapi/inc/class.egw_db.inc.php(676): egw_db->halt(‘Invalid SQL: SE…’, 1022, ‘/usr/share/egro…’)
#1 /usr/share/egroupware/phpgwapi/inc/class.egw_db.inc.php(2029): egw_db->query(‘SELECT SQL_CALC…’, 1022, ‘/usr/share/egro…’, 0, 999, false, 2)
#2 /usr/share/egroupware/etemplate/inc/class.so_sql.inc.php(1023): egw_db->select(‘egw_news’, ‘SQL_CALC_FOUND_…’, Array, 1022, ‘/usr/share/egro…’, 0, ‘GROUP BY egw_ca…’, ‘news_admin’, 999, ‘RIGHT JOIN egw_…’)
#3 /usr/share/egroupware/news_admin/inc/class.bonews.inc.php(312): so_sql->search(Array, ‘1’, ‘GROUP BY egw_ca…’, Array, ‘%’, false, ‘OR’, Array, Array, ‘RIGHT JOIN egw_…’)
#4 /usr/share/egroupware/news_admin/inc/class.bonews.inc.php(454): bonews->search(Array, ‘1’, ‘GROUP BY egw_ca…’, Array, ‘%’, false, ‘OR’, Array, Array, ‘RIGHT JOIN egw_…’)
#5 /usr/share/egroupware/news_admin/inc/class.news_admin_import.inc.php(146): bonews->get_cats(Array, NULL, NULL, true)
#6 [internal function]: news_admin_import->async_import(NULL)
#7 /usr/share/egroupware/phpgwapi/inc/common_functions.inc.php(907): call_user_func(Array, NULL)
#8 /usr/share/egroupware/phpgwapi/inc/class.asyncservice.inc.php(433): ExecMethod(‘news_admin.news…’, NULL)
#9 [internal function]: asyncservice->check_run(‘crontab’)
#10 /usr/share/egroupware/phpgwapi/inc/common_functions.inc.php(907): call_user_func(Array, ‘crontab’)
#11 /usr/share/egroupware/phpgwapi/cron/asyncservices.php(73): ExecMethod(‘phpgwapi.asyncs…’, ‘crontab’)
#12 {main}
James D Bearden
Nontrivial Solutions, LLC
http://www.nontrivial.net
mailto://james@nontrivial.net
(405) 593-8098
