Hi.
I have one installation with 1.6 under debian etch. I use LDAP for
accounts and works almost nice except for three reasons:
- I want use categories in addressbook contacts. I use SQL for
contacts, I enable the category tab to be shown, and have created global
categories in admin, and also under addressbook (hoping that there are
at least two possible “sources” for categories). However, though the
category tab appears, no category appears in the category tab to assign
to the contact. In the category dropdown box in the main addressbook
form, the categories do appear, so they exist. The user I’m using for
this is admin (I create users with this user), so I don’t think it’s a
privilege issue.
- I experience the “empty haystack” issue reported in the tracker.
Maybe that causes the above problem, who knows.
- Very often I have to re-re-retry several times login after logout,
and I’m sure the entered user/pass pair is correct. What I mean is that
login fails too often after a delay of about 10 seconds after I see the
"bad login" error, and I’m not sure what to check, because it’s random.
As a side note, I’ve tried to reproduce the same issue in 1) in my
laptop with ubuntu intrepid and it works perfectly (i.e., I can’t
reproduce the problem, but I don’t experience the issue 2).
Regards.
GPG Key at http://keyserver.pgp.com |
