Hello,
The docker ps is OK
my new problem, is I wanted to go back to 17.1, and I remove the database (I have a backup).
So docker-compose logs send me
egroupware | Retrying EGroupware installation in 3 seconds …
egroupware | /usr/bin/php7.3 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --setup-cmd-database sub_command=create_db ‘domain=default’ ‘db_type=mysqli’ ‘db_host=localhost’ ‘db_port=3306’ ‘db_name=egroupware’ ‘db_user=egroupware’ ‘db_pass=!fAT&4M)w4r9&?pD’ ‘db_root=root’ ‘db_root_pw=’ 'db_grant_host=localhost’
egroupware | Can not connect to mysqli database mysql on host localhost:3306 using user root! (ADOdb::Connect(localhost:3306, root, $Password, mysql) failed.)
egroupware |
egroupware | Installation failed --> exiting!
egroupware |
egroupware-nginx | 2019/09/15 13:52:23 [error] 6#6: *21 connect() failed (111: Connection refused) while connecting to upstream, client: 172.20.0.1, server: _, request: “POST /Microsoft-Server-ActiveSync?Cmd=Ping&User=benoit&DeviceId=android22947967&DeviceType=Android HTTP/1.1”, upstream: “fastcgi://172.20.0.3:9000”, host: "zelec.homelinux.net"
egroupware-nginx | 2019/09/15 13:52:23 [error] 6#6: *21 connect() failed (111: Connection refused) while connecting to upstream, client: 172.20.0.1, server: _, request: “POST /Microsoft-Server-ActiveSync?Cmd=Ping&User=benoit&DeviceId=android22947967&DeviceType=Android HTTP/1.1”, upstream: “fastcgi://172.20.0.3:9000”, host: “zelec.homelinux.net”
So where can I write db name, password …
I see this message
WARNING: Error loading config file: /root/.docker/config.json: read /root/.docker/config.json: is a directory
Is that important.
Thank you for your help
Benoit
