After installing egroupware, created admin accounts.
But not able to login with admin account.
After authentication egroupware gif keeps loading and never completes.
F12 shows following errors,
jquery.noconflict.js:16 U
ncaught ReferenceError: jQuery is not defined
at jquery.noconflict.js:16
(anonymous) @ jquery.noconflict.js:16
et2_core_inheritance.js:18 Uncaught ReferenceError: Class is not defined
at et2_core_inheritance.js:18
at et2_core_inheritance.js:158
(anonymous) @ et2_core_inheritance.js:18
(anonymous) @ et2_core_inheritance.js:158
fw_base.js:15 Uncaught ReferenceError: Class is not defined
at fw_base.js:15
at fw_base.js:1168
(anonymous) @ fw_base.js:15
(anonymous) @ fw_base.js:1168
config.php?1568654337&etag=3ffa64c814a5c51a7d08058e4a4f8eba:1 Uncaught TypeError: egw.set_configs is not a function
at config.php?1568654337&etag=3ffa64c814a5c51a7d08058e4a4f8eba:1
(anonymous) @ config.php?1568654337&etag=3ffa64c814a5c51a7d08058e4a4f8eba:1
images.php?1568654337&template=pixelegg&etag=5191a8d02b42001ca5360ce185837779:1 Uncaught TypeError: egw.set_images is not a function
at images.php?1568654337&template=pixelegg&etag=5191a8d02b42001ca5360ce185837779:1
(anonymous) @ images.php?1568654337&template=pixelegg&etag=5191a8d02b42001ca5360ce185837779:1
user.php?1568654343&user=egwadmin&lang=en&etag=b4e73fea48b63d7a62538b74d42abc03:1 Uncaught TypeError: egw.set_preferences is not a function
at user.php?1568654343&user=egwadmin&lang=en&etag=b4e73fea48b63d7a62538b74d42abc03:100:
Strange but httpd log do not show any error, is there any special command to enable egroupware logs ?
