Not sure that this is an error at all. Depends if there are linked files to
that tracker item. The sqlfs_stream_wrapper::url_stat just stats that there
is no file
connected to the tracker entry.
Are you able to attach files to tracker entrys, and retrieve them after
closing/opening the window?
In that case you may as well check and maybe rerun search and register hooks
of all applications.
This solved a maybe related problem (attaching files to trackerentrys) with
the egroupware org installation.
I dont think that this is an notification issue.
It seems to be an issue of retrieving linked information to/from an tracker
item. (As Christian
already pointed out)
Regards
Klausi
Hi Christian,
Too late indeed after spending too much time on this :-/
I’ll continue my search tomorrow and dive into sqlfs… thnx for replying,
Oscar
Hi Oscar,
a quick test on my /trunk didn’t offer me any problems with trackers
notifications…
Maybe it’s got something to do with links that point to sqlfs streams.
But hey, I’m just
guessing at the moment… it’s late.
Bye
Christian
Oscar van Eijk schrieb:
Hi All,
I’m experiencing problems with notifications, e.g. when tracker tries to
notify about
an update, the message:
sqlfs_stream_wrapper::url_stat(‘links://default/apps/tracker/100’,2)
file or directory not found!
appears in the PHP errorlog a few dozen times, no
notification is sent
in any way.
All configs are fine; not changed recently. It worked find in
1.5.003,
but since my recent upgrade to 1.6.001. Just moved to latest trunk
without
succes.
Anybody experienced this as well>
Thanks in advance,
Oscar
Create and Deploy Rich Internet Apps outside the browser with
Adobe®AIR™
software. With Adobe AIR, Ajax developers can use existing skills and code
to
build
responsive, highly engaging applications that combine the power of local
resources and data
with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building
applications today-[http://p.sf.net/sfu/adobe-com> > >
_________> eGroupWare-developers
mailing list>
href="mailto:eGroupWare-developers@lists.sourceforge.net">eGroupWare-deve
lopers@lists.sourceforge.net>
https://lists.sourceforge.net/lists/listinfo/egroupware-developers-------
-----------------------------------------------------------------------Cr
Adobe®AIR™software.
With Adobe AIR, Ajax developers can use existing skills and code tobuild
responsive,
highly engaging applications that combine the power of localresources and
data with the
reach of the web. Download the Adobe AIR SDK andAjax docs to start building
applications
today-http://p.sf.net/sfu/adobe-com
_________eGroupWare-developers mailing
listhref="mailto:eGroupWare-developers@lists.sourceforge.net">eGroupWare-deve
lopers@lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/
egroupware-developers -> http://p.sf.net/sfu/adobe-com]
Adobe®AIR™
software.
build responsive,
resources and data with the
Ajax docs to start building applications
mailing
list
[ open style of IT ]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon 06352 . 70629-0
fax 06352 . 70629-30
www.stylite.de
Geschäftsführer: Andre Keller, Gudrun Müller, Nigel Vickers, Ralf Becker
Create and Deploy Rich Internet Apps outside the browser with Adobe®AIR™
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
