How do I enable the Notification popup? I have egroupware-epl (16.1.20170315) Thanks //Ger
Please consider the environment before printing this email. Ger Hooton Systems Administrator Scoil Chroà Ãosa Blarney. Blarney. Co. Cork
Hi Ger,
You can switch notifications on by setting preferences-> Notifications -> Notify me by. There you can define what sort of notifications you would like to receive.
Best regards,
Thanks Hadi, Should I see “Notifications” in the preferences drop down list because I do not?
make sure that you have run access to Notifications app. You can do that by going to ACL dialog -> run rights for applications -> and add notifications.
Hope that brings your Notifications into the preferences list.
Sorry, how do I get to the ACL dialog ?
There’s an item on top menu which is called “Access”. (see the screenshots please)
Got it, thanks for all your help.
