Hi all,
I upgraded (and migrated) from old 1.8.007 version to actual 16.1 (20161208) and noticed some things during conversion. Although I have installed egroupware-epl-compat, during upgrade emailadmin was not installed (in debug log: process->upgrade(): Application not installed: emailadmin) and I can’t see it in app list. I don’t know if it is OK.
Now, when I run the test task in “Asynchronous timed services”, it works fine and I receive test email.
But when I create calendar event with notification, the task is visible in Asynchronous timed services, but after cron set time disappear and I doesn’t receive any mail. EGW probably does not use linux mailserver on the same machine, because in /var/log/maillog there is nothing at this time.
So I tried to create “SMTP only” mail account for all users, but the situation was not changed.
I don’t know, where should be a problem. Could anybody help me, please?
Thanks
Tony
P.S.: I think, that this issue must be related to upgrade to version 20161208, because in November, I was able to eGW instance fro 1.8 to 16.1 w/o any problems and after creating SMTP only account it worked fine…
