Hi Pavel,
Hi Ralf,
thanks a lot. We are still on eGW 1.8.
We customized the eGW a lot (only by eTemplate and some additional
functions). When we made an upgrade from 1.6 to 1.8, it took us a lot
of time to make all customization to work. So I am afraid to upgrade
to 14.2, or I am too busy
Is there a chance to have your update in egw 1.8?
If you backport it yourself …
When we make an upgrade to 14.2 is it sure it will be available as a
community version forever? Is there some reduction of functionality of
14.2 according to 1.8 (both community version).
You are asking if correct numeric sorting might sometime in future no
longer be available in CE version?
Don’t think so, it is such an esoteric feature.
I beg to differ here: as a matter of fact I’d like to patch my 1.8.x
to be able to do that too (in Addressbook->Custom Fields actually).
We have some data in custom fields, that does not fit any of the 'standard’
fields of Addressbook entries, and my requirement to users to precede the numbers
with leading zeros, for the sorting by that column to work, has been not
entirely understood either…
( a fitting example : datacenter rack / grid / shelf / switch / port number designation:
all fields up to say switch number can actually contain a-z,A-Z; but port is
in our usage, just numbered 1…X where x is usually 12, 24 or 48.
we have rack/grid/shelf/switch numbers in ‘selectors’ but the port number is a text field,
and it’s not funny to see port numbers sorted alphabetically like
1,10,11,12,13,14,15,16,17,18,19,2,20,21,22,23,24,25,26,27,28,29,3,30, etc.)
Unless you can advise of a js snippet to automatically fill in leading zeros ?
Lukasz
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
