Hi Horst,
OS/X 10.10.1
OS/X Contacts Version 9.0 (1499)
EGroupware 14.1 from 20141113.
When I add a new contact to the OS/X addressbook it crashes the
addressbook, when it tries to upload the new contact to Egroupware using
CardDav. There is no problem with modifying an existing contact. I am too do
not have this problem with the Address book on IOS devices and this problem
does not exist with Egroupware 1.8.007.
I have attached the log from the addressbook crash and the apache2 error
log.
That logs do not help, if the problem in on EGroupware side.
Apache error_log contains lots of warnings, which can be savely ignore.
Unfortunetly we can not supress them, if we want to support PHP 5.3+ …
For all CalDAV/CardDAV problems you need to to go CalDAV/CardDAV
preferences and switch in Logging / Debugging Tab “Enable logging” on by
setting it to “Requests and full responses to files directory”. Then
reproduce the action leading to the problem. Reopening (!) preferences
should now contain under “Show log of following device” an entry for
current date and your addressbooks user-agent eg. “30.11.2014, 10:12:
Mac OS X/10.10.1 (14B25) AddressBook/1499” for today and my OS X 10.10.1
addressbook.
That log contains all communication, plus errors and warnings from
EGroupware server.
Anyone out there using this without any problems?
I’m not experiencing any crash of OS X Addressbook, but I noticed a
wrong header in answer from EGroupware server, which I now fixed in 14.1:
http://svn.stylite.de/viewvc/egroupware?revision=49644&view=revision
You should apply the change to your installation or download the whole
file from:
http://svn.stylite.de/viewvc/egroupware/branches/14.1/addressbook/inc/class.addressbook_groupdav.inc.php?revision=49644&view=co&pathrev=49644
Btw. what OS X version are you using?
