I’ve tried to switch to mysqli, but after some page correctly displayed
i hit:
[Sat Aug 22 15:01:01 2009] [error] [client me] PHP Warning: mysqli_real_escape_string() [function.mysqli-real-escape-string]: Couldn’t fetch mysqli in /usr/local/share/egroupware/phpgwapi/inc/adodb/drivers/adodb-mysqli.inc.php on line 180, referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] PHP Warning: mysqli_query() [function.mysqli-query]: Couldn’t fetch mysqli in /usr/local/share/egroupware/phpgwapi/inc/adodb/drivers/adodb-mysqli.inc.php on line 701, referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] Database error: Invalid SQL: SELECT message_id,content FROM egw_lang WHERE lang=’’ AND app_name=’’, referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #0 /usr/local/share/egroupware/phpgwapi/inc/class.egw_db.inc.php(684): egw_db->halt(‘Invalid SQL: SE…’, 220, ‘/usr/local/shar…’), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #1 /usr/local/share/egroupware/phpgwapi/inc/class.egw_db.inc.php(1913): egw_db->query(‘SELECT message_…’, 220, ‘/usr/local/shar…’, false, -1, false, 2), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #2 /usr/local/share/egroupware/phpgwapi/inc/class.translation.inc.php(220): egw_db->select(‘egw_lang’, ‘message_id,cont…’, Array, 220, ‘/usr/local/shar…’), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #3 /usr/local/share/egroupware/phpgwapi/inc/class.egw.inc.php(197): translation->add_app(‘home’), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #4 /usr/local/share/egroupware/phpgwapi/inc/functions.inc.php(83): egw->wakeup2(), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #5 /etc/egroupware/header.inc.php(113): require_once(’/usr/local/shar…’), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #6 /usr/local/share/egroupware/index.php(55): include(’/etc/egroupware…’), referer: https://mysite/index.php
[Sat Aug 22 15:01:01 2009] [error] [client me] #7 {main}, referer: https://mysite/index.php
My setup, standard etch:
ii apache2-mpm-prefork 2.2.3-4+etch10 Traditional model for Apache HTTPD 2.1
ii php5-mysql 5.2.0+dfsg-8+etch15 MySQL module for php5
ii mysql-server-5.0 5.0.32-7etch10 mysql database server binaries
phpinfo() say:
mysqli
MysqlI Support enabled
Client API library version 5.0.32
Client API header version 5.0.32
MYSQLI_SOCKET /var/run/mysqld/mysqld.sock
Directive Local Value Master Value
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.reconnect Off Off
I’m not clear if this is an egw, a debian, or my fault, but really i’ve
not modified mysql configuration hardly…
Many thanks.
``… La memoria conta veramente solo se tiene insieme l’impronta del
presente e il progetto del futuro, se permette di fare senza dimenticare
quel che si voleva fare, di diventare senza smettere di essere,
di essere senza smettere di diventare…’’ (Italo Calvino)
