Ich habe folgende SW-Versionen:
EGW 1.6.003
Client:
Outlook 2003
Funambol 8.05
Synchronisation für Kontakte und Task funktioniert mit EGW.
Beim Versuch, den Kalender zu synchronisiern, bricht Funambol ab mit der Fehlermeldung: Sync not completed. See Log details.
Wenn ich den Log auf ‘Debug’ stelle, bekomme ich am Ende folgende Fehlermeldung.
Wäre schön wenn mir jemand helfen, könnte, diese richtig zu interpretieren.
Danke und Grüße
JK
22:05:54 GMT +1:00 [DEBUG] - Connecting to egw:80
22:05:54 GMT +1:00 [DEBUG] - Requesting resource /egroupware/rpc.php?syncml_sessionid=syncml-1d59d4fb2376d7394dbbb5798f0ae52a
22:05:54 GMT +1:00 [DEBUG] - Sending data of size 39720...
22:05:54 GMT +1:00 [DEBUG] - Message sent
22:05:54 GMT +1:00 [DEBUG] - Finished sending data of size 39720.
22:05:54 GMT +1:00 [DEBUG] - Data sent successfully to server. Server responds OK
22:05:54 GMT +1:00 [DEBUG] - Header: HTTP/1.1 200 OK
Date: Wed, 21 Apr 2010 20:06:40 GMT
Server: Apache/2.0.63 (Unix) DAV/2 PHP/5.2.5
X-Powered-By: PHP/5.2.5
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Content-Length: 354
Keep-Alive: timeout=15, max=99
Connection: Keep-Alive
Content-Type: text/html; charset=ISO-8859-1
22:05:54 GMT +1:00 [DEBUG] - Reading response…
22:05:54 GMT +1:00 [DEBUG] - Content-length: 354
22:05:54 GMT +1:00 [DEBUG] - Receiving data of size 354…
22:05:54 GMT +1:00 [DEBUG] - Finished receiving data of size 354.
22:05:54 GMT +1:00 [DEBUG] - Response read:
An error happened
An error happened
DateTimeZone::__construct() [function.DateTimeZone---construct]: Unknown or bad timezone ()
Click here to resume your eGroupWare Session.
22:05:54 GMT +1:00 [ERROR] - Server Failure: server returned error code -1
22:05:54 GMT +1:00 [DEBUG] - ---------------------- END (mode “none”) ----------------------
22:05:54 GMT +1:00 [DEBUG] - Error occurred in sync: code 3 = Server Failure: server returned error code -1
22:05:54 GMT +1:00 [ERROR] - Error in syncing: Server Failure: server returned error code -1
22:05:54 GMT +1:00 [INFO] -
================ SYNCHRONIZATION REPORT ================
SYNCHRONIZATION COMPLETED WITH ERRORS
Last error message = "Server Failure: server returned error code -1"
Last error code = -1
Calendar:
Sync completed successfully!
Sync type: slow (requested by Server)
| on Client | on Server
New | 0/ 0 | 0/ 0
Updated | 0/ 0 | 0/ 0
Deleted | 0/ 0 | 0/ 0
22:05:54 GMT +1:00 [DEBUG] - Saving configuration to winRegistry
22:05:54 GMT +1:00 [DEBUG] - Writing configuration settings to the management tree
22:05:54 GMT +1:00 [DEBUG] - Closing Outlook…
22:05:54 GMT +1:00 [DEBUG] - Deleting ClientApplication instance
22:05:54 GMT +1:00 [DEBUG] - Detaching IMAPIUtils object…
22:05:54 GMT +1:00 [INFO] - Outlook session closed successfully.
22:05:54 GMT +1:00 [DEBUG] - Closing COM library…
22:05:54 GMT +1:00 [DEBUG] - Releasing sync-mutex…
22:05:54 GMT +1:00 [DEBUG] - Sync-mutex released - closing handle.
22:05:54 GMT +1:00 [DEBUG] - Delete SyncSources…
22:05:54 GMT +1:00 [INFO] - Syncronization process completed with errors (code = -1).
