Hello,
I’ll try to be clear
I ve found that the filter added in the preference of syncml has a problem
for addressbook filter, you are force to choose a adressbook to sync with
but if you only want to sync contact from the distribution list. it was
not possible
the patch add a value None, in the list of preference adressbook to sync
with and the filter change in api.php
the patch is attach
I’m be glad to discuss the patch and help
cyril
