You are right, it should be a fatal error. Install the extension, it is required to import timezone data we use from Lightning. After installing the extension, admin >> calendar allows to manually import the tz file.
[ open style of IT ]
Morschheimer Strasse 15
D - 67292 Kirchheimbolanden
fon +49 (6352) 70629-0
fax +49 (6352) 70629-30
mobil +49 (170) 3147833
email rb@stylite.de
www.egroupware-support.eu
www.stylite.de
Geschäftsführer: Andre Keller,
Gudrun Müller, Ralf Becker
Registergericht Kaiserslautern, HRB 30575
Hi!
When updating 1.6 to 1.8, I get the following error message:
An error happened
calendar_timezones::import_sqlite(‘calendar/setup/timezones.sqlite’)
required SQLite support (PHP extension pdo_sqlite) missing!
… but in the installation checks, pdo_sqlite is marked with a warning
only (flash). It should display an error (“X”) if the missing extension
leads to an error message.
Does the above message have a negative impact on the behavior of the
calendar application and how could this be solved?
Thanks,
Hans-Jürgen
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
