Ralf, all,
I am having performance problems with 14.3 taking 3-5 times longer to login
and load than 1.8. What makes this much worse than it sounds is 14.3 is running
on an AMD FX-3850 (8-core) w/16G of DDR3 1866, while 1.8 is running on an old
AMD Athlon 2800 with 2G of pc3200 and 1.8 is still much more responsive.
Additionally I’m pulling the pages for 1.8 from a remote site over the internet,
while the 14.3 install is on my local area network.
The 14.3 install was a new svn install currently “Updated to revision 53890”.
All new pear requirements are met and all recommended php.ini size increases
incorporated. The egroupware/setup shows all requirements satisfied. So I’m at a
loss as to what possible setting could be causing the slowdown.
On login, there is only a single message displayed:
[Sat Oct 10 22:24:42.255912 2015] [:error] [pid 30817] [client
192.168.6.102:40632] egw_json_response::sendHeader() header already sent by
/srv/http/htdocs/egroupware_142/etemplate/inc/class.etemplate_new.inc.php line
224: egw_json_response::sendHeader:463 / egw_json_response::get:435 /
egw_framework::include_css_js_response:2275 /
calendar_favorite_portlet->exec:122 / home_ui->get_portlet:284 /
home_ui->index:75, referer:
http://valkyrie.3111skyline.com/egroupware/login.php?phpgw_forward=%2Findex.php
There are no other errors generated. Sometimes login to 14.3 just hangs and I
have to “refresh” to make the login work.
I have attached an xz zipped copy of the phpinfo. If anyone can think of why
I am getting this error or why I am having performance issues with 14.3 I would
welcome your thoughts. Thanks for any help you can offer.
David C. Rankin, J.D.,P.E.
