When contacts are fetched by Kontact from EGroupware, phone numbers have the
following types:
- Phone (work): VOICE,WORK
- Cell phone: CELL,WORK
- Phone (home): HOME,VOICE
- Fax: FAX,WORK
But if I edit a contact (for example by changing his company name) and resave
it, the cell phone number (“Work/Mobile” in Kontact) is interpreted by
EGroupware as the cell phone number, but also as the work phone number ! So,
even if there was a work phone number, it is replaced by the cell phone
number. I think the following types should be used instead to be coherent:
- Phone (work): WORK
- Cell phone: CELL
- Fax: FAX
Thank you,
Laurent Léonard
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
