Hi Anthony,
should be fixed with r34949.
Thanks for reporting
Invalid SQL: SELECT COUNT() FROM egw_categories WHERE cat_owner=0:
ERROR: operator does not exist: character varying = integer
LINE 1: SELECT COUNT() FROM egw_categories WHERE cat_owner=0
HINT: No operator matches the given name and argument type(s). You
might need to add explicit type casts.
The offending lines seem to be:
phpgwapi/inc/class.categories.inc.php:896: if
(!$GLOBALS[‘egw’]->db->select(self::TABLE,‘COUNT(*)’,‘cat_owner=0’,LINE,FILE)->fetchColumn())
phpgwapi/inc/class.categories.inc.php:898:
$GLOBALS[‘egw’]->db->update(self::TABLE,‘cat_owner=0’,"(cat_owner=-1 OR
cat_appname=‘phpgw’)",LINE,FILE);
Temporarily, modifying ‘cat_owner=0’ to ‘cat_owner::int=0’ solves the
problem, though it appears that the long term goal is to support
multiple numbers in the cat_owner field. This method won’t work for that.
WhatsUp Gold - Download Free Network Management Software
The most intuitive, comprehensive, and cost-effective network
management toolset available today. Delivers lowest initial
acquisition cost and overall TCO of any competing solution.
http://p.sf.net/sfu/whatsupgold-sd
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller, Ralf Becker
Achieve unprecedented app performance and reliability
What every C/C++ and Fortran developer should know.
Learn how Intel has extended the reach of its next-generation tools
to help boost performance applications - inlcuding clusters.
http://p.sf.net/sfu/intel-dev2devmay
