Hi Anthony,
not sure I understand what your problem is.
We recently introduced a fix to automatic quote mixed case column-names
for PostgreSQL and removed manual quotes in code:
http://svn.stylite.de/viewvc/egroupware?view=revision&revision=38307
We tested here two cases:
- new code working with existing wiki tables
- new code can create new tables and workes with them
So, what exactly is failing for you and is your installation up to date?
I just realized why I was having issues with my Wiki–in PostgreSQL,
column names like wiki_rate_viewLimit, must be quoted
CREATE TABLE egw_wiki_rate
wiki_rate_ip character varying(40) NOT NULL DEFAULT ‘’::character varying,
wiki_rate_time integer,
“wiki_rate_viewLimit” smallint,
“wiki_rate_searchLimit” smallint,
“wiki_rate_editLimit” smallint,
CONSTRAINT egw_wiki_rate_pkey PRIMARY KEY (wiki_rate_ip )
WITH (
OIDS=FALSE
ALTER TABLE egw_wiki_rate
OWNER TO egroupware;
Then things work again
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
http://p.sf.net/sfu/Boundary-dev2dev
