I’m trying to install JiNN on eGW 1.6 (from SVN), with several problems.
Actually I’m wondering if JiNN is still a live application or not:
Is anybody informed about its present and its possible future ?
However:
- I got errors in setup: PHPGW_SERVER_ROOT is not defined
- I defined it, added ‘1.6’ to [depends] in setup, and installed
- after created a site, creating the first object give the error:
Fatal error: Call to protected method egw_framework::_get_css() from context ‘common’ in C:\www\gw\phpgwapi\inc\class.common.inc.php on line 1036
Any hint ?
Thanks.
Andrea.
