Hello,
I did create a infolog type "Purchase Order"
I would like to create a specific print layout for this.
So I tried in etemplate to create infolog.edit.Purchase Order.print but that does’nt work (it takes the std layout not mine)
I also tried to create infolog.edit.Purchase Order. This is working, but when I try to print I get a new infolog edit window instead of the print layout window.
How do I have to do ?
Is it also possible to directly send the printout by mail ?
thanks,
SP
