Bonjour, j’ai un problém avec ASNYC
voici le message,
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/usr/bin/php) is not within the allowed path(s): (/home/www/c439cb651514afbf6db0bc463bbea10d:/tmp:/opt/php/lib/php) in /home/www/c439cb651514afbf6db0bc463bbea10d/web/webgest/phpgwapi/inc/class.asyncservice.inc.php on line 545
Warning: popen() has been disabled for security reasons in /home/www/c439cb651514afbf6db0bc463bbea10d/web/webgest/phpgwapi/inc/class.asyncservice.inc.php on line 555
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/usr/bin/php4) is not within the allowed path(s): (/home/www/c439cb651514afbf6db0bc463bbea10d:/tmp:/opt/php/lib/php) in /home/www/c439cb651514afbf6db0bc463bbea10d/web/webgest/phpgwapi/inc/class.asyncservice.inc.php on line 545
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/usr/bin/php5) is not within the allowed path(s): (/home/www/c439cb651514afbf6db0bc463bbea10d:/tmp:/opt/php/lib/php) in /home/www/c439cb651514afbf6db0bc463bbea10d/web/webgest/phpgwapi/inc/class.asyncservice.inc.php on line 545
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/usr/bin/crontab) is not within the allowed path(s): (/home/www/c439cb651514afbf6db0bc463bbea10d:/tmp:/opt/php/lib/php) in /home/www/c439cb651514afbf6db0bc463bbea10d/web/webgest/phpgwapi/inc/class.asyncservice.inc.php on line 545
merci d’avance pour votre aide,
S.Gaido
