Hallo Martin,
browser cache leeren war kein erfolg. Das sind die Meldungen vom Apache:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] PHP Warning:
filemtime(): stat failed for
/var/www/vhosts/xxxx/subdomains/egw/jdots/js/egw_fw.js in
Der findet alle möglichen Javascript Files nicht, könnte an den
Permissions liegen …
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.egw_framework.inc.php
on line 1997, referer:
http://egw.xxxx/login.php?cd=10&phpgw_forward=%2Findex.php
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #1
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.egw_framework.inc.php(1997):
filemtime(’/var/www/vhosts…’), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #2
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.egw_framework.inc.php(1950):
egw_framework::bundle_urls(Array, 0), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #3
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.egw_framework.inc.php(1907):
egw_framework::bundle_js_includes(Array), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #4
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.egw_framework.inc.php(1425):
egw_framework::get_script_links(true), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #5
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.egw_framework.inc.php(819):
egw_framework::_get_js(Array), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #6
/var/www/vhosts/xxxx/subdomains/egw/jdots/inc/class.jdots_framework.inc.php(351):
egw_framework->_get_header(Array), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #7
/var/www/vhosts/xxxx/subdomains/egw/pixelegg/inc/class.pixelegg_framework.inc.php(62):
jdots_framework->header(Array), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #8
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/inc/class.common.inc.php(997):
pixelegg_framework->header(), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #9
/var/www/vhosts/xxxx/subdomains/egw/index.php(123):
common::egw_header(), referer:
[Mon Mar 09 19:15:31 2015] [error] [client 188.193.138.202] #10 {main},
referer: http://egw.xxxx/login.php?cd=10&phpgw_forward=%2Findex.php
Instance=default, User=, Request=GET
http://egw.xxxx/index.php?cd=yes, User-agent=Mozilla/5.0 (X11; Ubuntu;
Linux x86_64; rv:36.0) Gecko/20100101 Firefox/36.0, referer:
/var/www/vhosts/xxxx/subdomains/egw/jdots/js/egw_fw_ui.js in
/var/www/vhosts/xxxx/subdomains/egw/phpgwapi/js/jquery/magicsuggest/src/magicsuggest-1.3.1.js
in
egw_framework::bundle_urls(Array, 1424257084), referer:
gruss
martin
was sagt das apache-log? Browser-Cache geleert?
Moe
Hallo zusammen,
ich verwende seit langer Zeit die eGroupware und hatte erfolgreich
auf die
Version 14.1 (EGroupware Version 14.1.20141021) aktualisiert. Jetzt
wollte
ich das Update auf die 14.2 einspielen und nachdem Anmelden
erscheint nur
die Blaue Menuzeile und in der linke Haelfte ein grauer Strich der
rest von
der Seite ist weiss. Hat einer einen Tip wie ich die 14.2 zum laufen
bekomme? die PHP Version ist PHP Version 5.4.36-0+deb7u3.
Vielen Dank fuer Eure Hilfe.
gruss
martin
Dive into the World of Parallel Programming The Go Parallel Website,
sponsored
by Intel and developed in partnership with Slashdot Media, is your hub
for all
things parallel software development, from weekly thought leadership
blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
