Da ich dasselbe Problem wie erz / Erich habe, melde ich mich auch nochmals zurück, nämlich zu Brigitte’s Wortmeldung:
Bei mir steht da:
[Thu Aug 07 20:36:51 2014] [error] [client IP-Adresse] etemplate_request::r
ead(‘mail_user_vieleZahlenundZiffern’, …) eT2 request not found / ex
pired --> redirecting app mail to /index.php?menuaction=mail.mail_ui.index&ajax=
true (_GET[menuaction]=mail.etemplate_new.ajax_destroy_session.etemplate, isJSON
Request()=TRUE), referer: http://meineDomain.com/egroupware/index.php?cd=yes
[Thu Aug 07 20:36:51 2014] [error] [client IP-Adresse] PHP Deprecated: mys
ql_connect(): The mysql extension is deprecated and will be removed in the futur
e: use mysqli or PDO instead in /usr/share/egroupware/phpgwapi/inc/adodb/drivers
/adodb-mysql.inc.php on line 349, referer: http://meineDomain.com/egroupware/index.
php?cd=yes
[Thu Aug 07 20:36:52 2014] [error] [client IP-Adresse] emailadmin_imapbase:
:openConnection (841) ->open connection for Server with profileID:8 failed!Tried
to access unknown attribute ‘capability’!, referer: http://meineDomain.com/egroupw
[Thu Aug 07 20:36:52 2014] [error] [client IP-Adresse] PHP Deprecated: mys
php?cd=yes
[Thu Aug 07 20:43:15 2014] [error] [client IP-Adresse] mail_hooks::notifica
tion_check_mailbox700 # (user: user): cannot connect to mailbox with Pr
ofile:8. Please check your prefs!, referer: http://meineDomain.com/egroupware/index
.php?cd=yes
tion_check_mailbox701 # emailadmin_imapbase::openConnection failed to emailadmin
_imapbase::openConnection on Profile to 8 :Tried to access unknown attribute ‘ca
pability’!, referer: http://meineDomain.com/egroupware/index.php?cd=yes
tion_check_mailbox702 # Instance=default, User=user, referer: http://meineDomain.com/egroupware/index.php?cd=yes
[/quote]
[quote=“Birgit Becker, Stylite AG”]Und wie sind die Ordnernamen z.B. Sent zustande gekommen? Capability ist
etwas was ein IMAP-Server setzen/melden kann z.B. um den sent-Ordner zu
spezifizieren. Im Prinzip versuchen wir das vom IMAP zu bekommen, man
kann es aber auch per Hand eintragen, dann muss es den Ordner aber auch
so geben. Es gibt ja auf dem IMAp z.B. auch unterschiedliche
"Trennzeichen" sodass es entweder Inbox.Sent oder Inbox/Sent sein kann.
[/quote]
Ich habe im Tab Ordner die richtigen / vorgefundenen IMAP-Ordner zur Auswahl gehabt und dort jeweils den entsprechenden übernommen. Von daher verstehe ich nicht, wieso es dann daran scheitern soll, einen Mailaccess einzurichten - die Trennzeichen wurden ja ausgelesen und gesetzt. Und die Inbox sollte trotzdem lesbar sein. Aber wo soll man ansonsten “Capability” von Hand eintragen?
Sorry, aber ich bin echt etwas überrascht, dass so etwas nicht out-of-the-box funktioniert, es ist schliesslich etwas vom ersten, was man beim Setup und Testen macht: Das viel beworbene Mailmodul einrichten.
Gruss,
Georg
