You guys get anything in your webservers error_log?
responding is probably different, as compose is involved there too.
If it is related to imap_rfc… functions, as I suspect, it might be,
it may be influenced by the settings for magic_quotes_gpc.
But this depends highly on where you are actually seeing the problem.
If the issue is as stefan reported while composing (reply) you may start by
checking with function getReplyData in class.bocompose.inc.php
This function reads the mail, prepares the reply data for compose, and
stores
them with the session. uicompose reads the session data and presents the
compose window.
Best regards
Klaus
06:35:24 -0800 (PST)
Hi Klaus, hello List.
I’ve got nearly the same problem as described before (don’t know exactly
since when this appears, but must be inside of the last 20 svn versions).
Our problem is, that there is no more to-field entry shown, when we try to
respond to any message, thought there is a sender shown in the the
original
from-field.
I’ll try to investigate more in this case, but I have no clue where to
start
Greetings from Hamburg
View this message in context:
http://n3.nabble.com/Problem-in-felamimail-in-To-field-tp694873p7005
47.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
[ open style of IT ]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon 06352 . 70629-0
fax 06352 . 70629-30
www.stylite.de
Geschäftsführer: Andre Keller, Gudrun Müller, Ralf Becker
USt-ID: DE214280951
