Hi Claudia,
I am trying to install egroupware 16.1 on Centos 6 (php version is 5.6.24)
and when I run
yum install egroupware-epl
I get this:
Installing : egroupware-epl-16.1.20161107-1.1.noarch 1/1
chcon: can’t apply partial context to unlabeled file backup' chcon: can't apply partial context to unlabeled file016345b88fbc02746a896dbaa2c17abc.php’
chcon: can’t apply partial context to unlabeled file `header.inc.php’
setsebool: SELinux is disabled.
That’s ok, nothing to worry about, you simply have SELinux disabled.
PHP Warning: include(/usr/share/egroupware/phpgwapi/setup/setup.inc.php):
failed to open stream: No such file or directory in
/var/lib/egroupware/header.inc.php on line 90
PHP Warning: include(): Failed opening
’/usr/share/egroupware/phpgwapi/setup/setup.inc.php’ for inclusion
(include_path=’.:/usr/share/pear:/usr/share/php’) in
PHP Notice: Undefined variable: setup_info in
/var/lib/egroupware/header.inc.php on line 91
/var/lib/egroupware/header.inc.php on line 92
PHP Warning:
require_once(/usr/share/egroupware/phpgwapi/inc/common_functions.inc.php):
/var/lib/egroupware/header.inc.php on line 108
PHP Fatal error: require_once(): Failed opening required
’/usr/share/egroupware/phpgwapi/inc/common_functions.inc.php’
EGroupware install log saved to /root/egroupware-epl-install.log
Verifying : egroupware-epl-16.1.20161107-1.1.noarch 1/1
Looks you are not installing but updating an older EGroupware. In that
case you need to also install egroupware-epl-compat package containing
old phpgapi directory which is references in your header.inc.php.
After you updated AND wrote a new header.inc.php (Setup lower login:
Header admin), you can remove the package again.
Let me know how it goes.
Installed:
egroupware-epl.noarch 0:16.1.20161107-1.1
And all I get in my browser when I point to mydomian/egroupware is a blank
page and thi error in the log:
(include_path=’.’) in /var/lib/egroupware/header.inc.php on line 90
PHP Warning:
(include_path=’.’) in /var/lib/egroupware/header.inc.php on line 108
Please help! Thanks.
Claudia Burman - Argentina
Telefon +49 631 31657-0
