Hi Christoph and Niels,
if it’s really r25343, then the Sogo fix makes the problem - thought I
dont think so:
http://www.egroupware.org/viewvc/trunk/addressbook/inc/class.vcaladdressbook.inc.php?r1=25343&r2=25342&pathrev=25343
Try reverting it with:
cd egroupware/addressbook/inc
svn merge -r 25343:25342 class.vcaladdressbook.inc.php
And check if that fixes the problem.
To revert to the current version of the file use:
svn revert class.vcaladdressbook.inc.php
If that’s not the problem, I would suspect r25291:
http://www.egroupware.org/viewvc/trunk/addressbook/inc/class.vcaladdressbook.inc.php?r1=25285&r2=25291&pathrev=25343
Unfortunately you cant merge that one back, as it gives a conflict.
You have to do it by hand. It’s enought to undo the first block (line
110ff).
Christoph Kaulich schrieb:
Hillo,
I have the same problem with trunk and a Nokia E61. I think it is broken
since r25343, but I am not sure about that.
At this time I moved my contacts from LDAP to MySql as well, so I
couldn’t identify the breaking point.
BTW: Groupdav is working very well, using the Sogo connector 0.62 from
Inverse, please try keeping both working.
Thanks
Christoph
Niels Przybilla schrieb:
Hello,
I use the trunk version.
it is:
eGroupWare http://www.egroupware.org/ Version 1.5.010
SyncML 1.4 1.4
Addressbook 1.5.001 1.5.001
Best regards
Niels
Ralf Becker schrieb:
What version (1.4.??? or trunk from ???) and which application
(addressbook, calendar, …) are you talking?
ich synce mein Nokia E90 Communicator mit Egroupware.
Sync funktioniert auch.
Aber statt der Sonderzeichen kommt statt ö ein A(Pi) habe kein zeichen
für Pi auf der Tastatur.
Ich habe den Zeichensatz schon voin ISO auf UTF-8 umgestellt.
Was könnte ich noch tun ?
Beste Grüße
Niels Przybilla
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don’t miss this year’s exciting event. There’s still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Telefon +49 (0)631 31657-0
