Hi
You’re right - there’s no problem if you create folder on the mounted
drive.
But if you try to copy existing folders /files from f.e. C:\ drive to
mounted drive, the folders /files which begin with ‘special’ letters
will be copied with wrong name - copying will skip these letters.
There’s no problem, if the ‘special’ letter is not at the beginning of
the folder /file name.
F. e.:
problematic names:
Čas
Žur
Šal
non-problematic names:
Kača
Anže
Hiša
Do you have an option to try some other tool (webdav client) on Windows?
Regards
Dne 31. 07. 2012 11:18, piše Czech users PL:
Thank you for your reply.
I agree that he’ll create a new folder so it is OK, but when I give a copy
to a folder on the server at the moment so will not create the initial
letter.
I tried it several times and always the same result. I tried it in the
openSUSE KDE Dolphin via webdav
/ www.domain.com / egroupware /
webdav.php / home. Same problem. Once you give the folder or file kpírovat
beginners,Ž, Š, Č, and the server is created. Otherwise, I think that
everything I nastveno well.
Please if you can try doing it too?
Thank you for your willingness.
