I experience the following behaviour using 1.4.002:
We use grouplanner, planner by users as default view, preselcted group is set to GroupA
calendar is start app, too, default view should be shown entering egroupware
Anyway sometimes, when users login (seems to be on the very first login of each user) the group-planner for Group “Default” is selected, whit the error message cause insufficient rights.
We forced GroupA, and the persmission are set for GroupA, and GroupA is the "preselectedgroup-for entering the planner"
Is it possible that the “preselected group for entering the planner” is somehow not evaluated regarding the calendar shown as start app.
Using the calendar the user sometime switch to “Default” calendar, too (not the users, but the app itself does it) getting the same error message.
I am thinking about deleting Group “Default”.
Is this a bug?
Thanks Frank
