which EGroupware version are you talking about (eg. 1.6.002 package, or
daily snapshot or svn update from xyz branch as revision z)?
Das to problem still exist using an up to date trunk?
rocas110 schrieb:
I have a small problem and not know if I could be directed or is it a bug of
egroupware, the fact is that when I save an activity in the egroupware and
outlook when I synchronize with desface makes an hour. For example: "If
captured and put an Activity Reunion which is 9:00 to 10:00 Am, is captured
from the egroupware when synchronize outlook appears in the same activity
only when it seems now varies from 8:00 Am-a 9:00.
The detail is that only me that desface hce October 25 to October 31, the
other dates are captured me well or synchronize the two applications without
any problem.
Right now I made a cal harm also trying another instalae the egroupware
server and I do the same on October 25 to October 31 all activities one hour
before the move.
I test adding activities in the outlook and sync and went for that activity
in the BD, and what I find is that the BD is well grabadadice date and the
same time I have in the outlook, try recording the activity from the
egroupware and check in the DB and then I recorded the activity but only an
hour earlier in the period October 25 to October 31, not if you have
something to do with the time change.
Greetings
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
