Hi Luca,
Luca Tolomelli schrieb:
I’ve opened a bug issue here:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2293
and here:
http://www.scalableogo.org/bugs/view.php?id=63
And this is the essential part:
There is a problem with the Sogo Connector 0.96 (and 0.95) for
Thunderbird: it simply doesn’t sync the address book any more.
With the Sogo Connector 0.94 it works fine.
This is a call in the error log with the connector 0.96 (not working properly):
[Fri Oct 09 12:36:38 2009] [error] [client 172.20.254.176]
groupdav::PROPFIND(Array([path] => /addressbook/[depth] => 0[root] =>
Array([name] => propfind[xmlns] => DAV:)[props] => Array([0] =>
Array([name] => resourcetype[xmlns] => DAV:)[1] => Array([name] =>
supported-report-set[xmlns] => DAV:)[2] => Array([name] =>
getctag[xmlns] => calendarserver.org/ns/))))
This is a call in the error log with the connector 0.94 (working properly):
[Fri Oct 09 12:50:04 2009] [error] [client 172.20.254.176]
Array([name] => resourcetype[xmlns] => DAV:))))
It seems that the extra info are causing problems to eGroupWare.
[1] => Array([name] => supported-report-set[xmlns] => DAV:)[2] =>
Array([name] => getctag[xmlns] => calendarserver.org/ns/
supported-report-set is a requirement and CardDAV servers must
"advertise" available reports with that. We can easily add that -
thought I need to find out the syntax (rfc’s can be a bit cryptic).
I still wonder that the missing property should be the cause for the
connector not working anymore. So far SOGO connector used for the
addressbook only a GroupDAV subset with PROPFIND. Only for readonly
addressbooks they used CardDAV REPORT’s.
ctag’s are optional (an extension) and not yet supported by EGroupware.
That should be no problem.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
